- Coupe dies on restart
- I need Opinions on a plenum spacer
- HELP...engine tick, tick, tick
- problem with start up
- fuel type?
- Castrol Top Shop Challenge - VQ Build
- AMSOIL, ridiculously expensive, but worth it?
- Adding rev up harness to motor in car???
- Walbro 255 and vortech
- Rev-Up Redline Question...Yes, I searched!
- Whirring/resonating after dealer "fixed" it... Help!
- KCR Headers
- Help
- What spark plugs do you use? bosch? NGK? Pulstar?
- Haltech 350 ECU
- Alternator Squeals with Load !
- Having a problem with Cold Start?
- Brand New G35 Longblock... Question...
- HELP! my car throttles on its own when slowing down.
- Idling problem- Please help!
- Enhgine over heating help
- Exhaust
- reprogramming kit info plz :)
- sigh....another problem!!
- Motordyne Spacer?
- Quick question regarding ATF pan + Antifreeze Drain...
- Did Search, Cant find anything Usefull.. Ichiba or Long Tube Header Question
- g37 oil analysis
- Idle?
- vortech question
- Motor Build Question
- My g is burning oil and makes a little squeak
- Close "money shift" call... Possible damage?
- German Castrol Syntec vs Castrol Edge
- finally installed my 5/16 plenum spacer, ztube, and k&n drop in but VERY SAD ;[
- Manumatic Mode
- Best Mods for Low End Gains
- Tcm replacement
- Throttle body spacer
- Need help with check engine light! Neutral Switch
- eBay Radiator support question
- 100K miles - time to do a maintenance overhaul
- mods: cheap ones that work
- Radiator on budget?
- HIGH REV parts on DE (intake manifold / dual intake conversion)
- Low dyno question
- throttle body spacer
- Car stuttered and dies on Interstate then started 5 minutes later..what going on??
- Need Tech Help
- hard to get into 5th and 6th gear
- Planning to mod my G. But before I do, I have some questions
- Help! Second throttle body dying on me? - P0506 P2135
- Front axle/engine area raspy noise issue- Please help!
- Axle / engline area raspy sound.
- plenum spacer
- z1 motorsports
- engine stalling, please help
- Ebay poly motor mounts...thoughts?
- Fuel Filter
- Brand o2 sensors?
- Am i lowered????
- What mods are left?
- 2003 G35 Two Problems - Cruise Control (P1574) & Turn Signal Issue
- Type of Coolant
- How big is the gas tank?
- Vortech boost gague install?
- OEM 350z strut bar?
- Will headers add how much hp?
- My mods, What should my car run and hp?
- Am i running rich??!!
- Hey what year is the engine rev up????
- Give me your opinion. 400 HP?
- More growl
- 20k to spend on my g35
- Having a bad day
- Couple questiongs regarding Turbonetics ST setup?
- condenser fan operating correctly?
- Iriduim Plugs
- New battery installed, engine stalls @ start-up
- strange problem, need answer
- knock-off ARC product?
- 04 coupe wire harness with utec
- check engine light (code 2135, throttle position sensor) on after new brake install
- Looking for used 600cc injectors or 255lph full pump
- blown fourth cylinder
- my car backfires !
- G35 Coupe-- Steering wheel hard to turn
- Spark Plug Questions!
- The future of the VQ, how big or how high can it go?
- Need parts new or used for turbo setup
- ecu flash
- Should I put single or twin turbo?
- Anyone Running the top speed n1 on their sedan?
- checking the dipstick!?!?
- car shut off while driving
- Upgrade Paths!!!
- VQ Power Path!!!
- Auto VQ into Stick Coupe??
- Check engine codes
- MREV2 install ques
