- "Boreing out the engine"
- Broken K&N Typhoon Intake
- Should the Horn sound when I lock the car?
- Mobil1 Extended Performance - 15,000 miles
- Updated 2005 Intake Manifold Collector
- Skid plate fugged
- Ticking question
- Ztube question
- has anyone removed the lower plenum?
- Recommended G35 Installers for Headers in San Diego?
- Surprising Oil Analysis Results... is dino better than synthetic?
- JWT Popcharger: what happens if you dont clean filter
- Crawford cast plenum arrived today
- Chip On Ebay?
- How to clean INJEN CAI???
- Question about sport wheels?
- radio on while car is off?
- spark plug
- Crawford Plenum on an 05 coupe 6MT?
- $55 Test Pipes for the G35, has anybody tried these?
- diffrent horn?
- Hey!
- motordyne 3/8" performance data
- DOT3 vs. DOT4
- Cleaning Stillen CAI
- Air Filters
- Best fuel system cleaner? Do they even work?
- Problems/issues w/ G35 need some help
- Clicking Noise???
- Vid: Dyno'ed my coupe
- G35 Dyno Result Compilation
- I blew it....
- Whats this?
- Anyone put an aftermarket Alarm System IN????
- Unorthodox Racing Performance Pulleys
- Whats the best Intake
- Pics of engin wheels subs etc.
- G35 extension for nismo cat-back
- Hotchkis installed... few days later knocking sound?
- OBX Racing Y-Pipe
- Recommandation is needed for new ECU
- This Might Be A Dumb Question
- Warranty and Mods, the Final Answer?
- Plenum Spacer and Your Warranty
- Need help!
- My Motordyne 1/2" Spacer Power Gains
- Nismo Guage Cluster/Speedo ?
- TSBs
- G-tech pro or Escort?
- Easy Question Regarding Escort 8500 x50
- revhighonline.com / Injen SES
- Motordyne Spacer dyno test results
- question about plastic undertrays
- Please Helpp!!!!!!
- Please help with Gord's TCU/ECU Wire Install
- Injen Intake is now Installed!! w00t
- Dynojet vs Mustang Dyno
- Oxygen Sensor Splice
- Is It Worth It?
- Horse power increase on 2005 stick verse auto
- Best Road to Accelleration?
- Need Actual Link to get MotorDyne Plenum Spacer
- Body Repair (cosmetic) suggestions in Los Angeles?
- Does the G35 have an OEM oil cooler?
- Place that sells OEM Parts
- ECU Chip
- ECU tuning option
- New to the G35
- Will a 350Z engine cover fit a G35 with the Crawford plenum?
- I Need Help With A Dent!!!
- G on 20s
- Slight whistle during hard accelaration
- Basic Mod List
- Type of Modifications That Wont Void Warranty
- Types of Modifications You Can Do To The G That Won't Void The Warranty
- Circle Earth HKS: Lost in the hieroglyphics
- fair price for used coupe mid pipe?
- What does a pop charger do?
- Buddy Club Ground Wire Stablizer Kit?
- When to do ECU?
- Calling ALL DATALOGGERS...
- engine shuts off
- Cats install goes awry
- How is the filter setup with the Vortech?
- fuel light comes on when i still have 6 gallons left
- Half-A** Spacer
- Where to Buy Crush Washer for Oil Drain?
- You know the old Question? Injen & water?
- Emerg/Hand Brake Adjustment
- ECU Reflashing/remapping tool
- Crawford Performance Cast Plenum Question?
- The Best Remote Starter
- Stillen Engine Dampener Brace
- horrible noise on startup
- Just got my New 05 G35 Coupe 6MT !
- Problems with Crawford....
- stock cat diameter??
- compass malfunction
- do you need to tune car after mods?
- Anybody install performance ignition wires?
