- Intake Manifolds?
- wrong gas
- Idle all messed up, and my G tried to kill me!
- WHO HAS a STILLEN engine damper brace
- 06 spark plug
- How Frequently should we replace spark plug?
- Car won't start! Single click and that's it.
- Idle Air Control Valve
- Motordyne 1/2" Copper Iso Thermal Plenum Spacer anyone?
- Flushed my Radiator Yesterday....
- stiffy
- Car acting up vdc and slip light..
- Oil in the spark plug gap
- any harm from this?
- Fast Intentions HFC+ Catback Exhaust::PICS+VIDS::
- My first oil change...hooray!!!!!!!
- LFR6AIX-11 or LFR5AIX-11
- Weird Noise, Smell today
- 70K Powertrain Warrantie
- 2003 G35 Coupe 70K Miles
- Service Engine Soon Light
- ntk about injectors for tt g35
- vortech fuel system question
- Fresh build
- engine rattle at startup?
- motor problem
- G35 o2 simulator
- Questions about first oil change
- Problem w/ Vortech Installation
- Variable Timing Sensor question
- Noob ?
- How to make 350Z Radiator fit G35? Fan Wiring?
- Cooling Problems HELP!
- Exhaust Rattle
- SES Light?? rough idle
- Is it possible to short belt VQ around PS pump?
- Top speed silencers.
- Opinions on Blox Spacer 5/8
- Help Motordyne
- oem spark plugs or ngk ones?
- jwt= pissed!!
- decided on Amsoil
- Is royal purple the most superior oil out there?
- before i get a md spacer..
- Official: Car won't start
- Help please ASAP.
- Reading ECM Harness voltages
- Going FI, which Oil to use?
- turbonetics kit with HKS Hi-power
- spark plug question
- Where does this plug go? And other questions :)
- fluid change at 70000
- where do i find the vin on my engine
- Beware of Weapon-r power steering tank!
- Purlator PureOne oil filter...
- Strange 'flutter' noise from engine - seems like a little loss of power !
- ecu reset after plenum/mrev2 install?
- shifter barring
- Suggestions for Modifications?
- Crush Washer
- midpipe question
- My car overheated!
- f/i to n/a?
- how long does it take infiniti to put in a new engine.
- Dm2 Idler spacer install
- Sale on Castrol Syntec at Autozon
- Custom 3.5" (90mm) CAI in the works
- Serious Fuel Smell....
- asking price for 04 VQ/6speed engine/trans
- New stillen radiator now fans always on???
- Help! Serious ticking noise coming from engine!
- Misfire on cylinder 6!
- Anyone have complications with spray?
- Idle pulley delete w/ DM2 spacer
- APS TT on G35x
- Early 03 sedan auto reflash updates:
- Engine fan running continously?!
- V8 Swap
- ok so im new :)
- Where can i buy the Mt Fuji emblem that comes on the stock engine cover?
- My DIY coolant drain, flush and fill
- anyone have AAM Comp Angled Intake Plenum Spacer
- Very disappointed in my mods, Please Help out, maybe i got a problem or something,
- plenum question
- Grounding Wire Recomendations?
- a little help on plenums
- Want More Power !!!
- need help
- '04 G35 Sedan Engine Tick
- what intanke to put on my g35???
- Serious question about my engine PLEASE HELP
- Need An Expert On Interlock!
- Neo Oil
- Someone please tell me what goes here!
- Megan v2 Test Pipe Question
- Tuners or programming chips
- Cost of changing DRIVE BELT
- Is anyone running Nitrous on their G35's???
- Timing chain or valve noise?
- need help 04 g35 missfire
