- HELP: Drivetrain Guru's Please look
- Accelerator Pedal Released Position Learning & Throttle Valve Closed Position???
- bore out throttle body.. mrev2.. bore that too maybe
- When to replace drive belt? whisling noise
- How to replace the cabin air filter?
- MAFs, Throttle Body & Ignition coils same as other VQ35 cars?
- Using filter plate for oil cooler, where else does oil temp sensor go?
- Question about part of engine.
- Help! i bought new spark plugs NGK-r
- P2135 code - reset ecu
- Aem Fic
- iso thermal bypass valve?
- random Air flow calculations
- Infinity says it can't be done RAISE my G35S idle
- Need some suggestions, Thanks a lot!
- can anyone do this?
- Mexican Gas Pemex
- something very odd....
- Intakes
- Ordered new exhaust. Couple Questions..
- cleaned throttle body, installed z-tube, now check engine light :(
- HP Difference in MT and AT
- For all you HKS exhaust owners for the coupe...
- Engine Knocking noise, guess what dealer said
- Valves smash into pistons??
- Help: my 03 coupe is knocking
- MD 5/16 plenum spacer and Injen intake
- Automatic shift kit
- between H and L
- 03 coupe misfireing
- Good mechanic in Dallas/Ft. Worth area?
- installing wideband and possibly R920 Brockway please some input here
- whats rev-up and non rev-up??
- WR damper install, need help!
- G35 Camshaft Install
- Service engine light @ 82k ?
- Do you have a blown motor?
- Refilling the A/C Freon on a G35 coupe???
- AEM Wideband
- Question about 05 oil consumption
- How much oil should an 07 coupe burn?
- "Service Engine Soon' light on dash
- what is rev up engine and this tsb oil thing??
- engine code P1121
- dealership said they cant raise idle??!!?
- Oil Change: Dealer vs. any other oil change place.....
- changed oil with 5.75 qts?
- motordyne spacer
- kinetix plenum?
- CLICKING please help....
- motordyne 1/2 iso therm spacer
- radiator fluid?
- cheack engine light.. help
- My Engine's Shaking?
- Dealership Engine Replacement Question?
- Dealer told me synthetic oil not recommended
- underdrive pulley
- Stillen Srut, Clearance? Help?
- stillen s/c
- Fx35 fan noise/vibrations question
- air filter
- benefits from getting this AAM spec long block
- oil catch can
- 2006 FX 35 Seafoam
- well, oil consumption has claimed another..
- Pro-1 Engine Damper
- GroundingGear® on 6MT
- No Sprak Help!!!
- What kind of engine oil should I use?
- what mods to get first
- rev-up and non rev-up
- How do I bleed the cooling system?
- Spacer Question
- MPG: 87 vs. 91
- Spark Knock/Pinging
- Unplug battery on G
- Starting with these mods...
- Have you had
- Pulsar Plugs
- rear brakes / drive belts gone after 44km?
- Car starts, but shuts off, unless gas is applied
- HELP!! Throttle Not Working; Car is Fully Disabled
- water-methanol injection
- Stillen Radiator
- stupid ques. rev up & non rev up
- Hard Cold Starts :(
- REVUP or non REVUP that is the question
- How do I replace the battery
- Strange noise when A/C is on
- intake vortex?
- Unichip
- How can you permanently disable VDC?
- Stock Wideband
- help in DIY for Injen cold air intake
- Optional Rear Active Steering Package
- New Radiator option from Stillen?
- Gauge Cluster goes awry
- Nitrous Thread
- Which year would you start with???
- Factory lower Plenum question
