- Battery drained??
- Car still pinging
- car turned off on me .....
- Experienced Members Only
- Quarter Mile Times???
- MotorDyne Copper Throttle Body heater installation... help!
- Well I've decided to go just 5/16" iso
- ECU Reset before Dyno Pulls?
- What To Do Next
- Question = Motordyne 5/16" spacer
- SES - Help!
- HP gain question for a newbie....
- Engine Management - Can the EXPERTS write a primer here?
- Picture of Gauges
- Thinking about cams?
- weight of hks hi power
- Alternate Fuel
- AccessPORT EMU for G35
- Spacer or Spacer/MREV2 combo?
- Cipher....wiring?
- RevUp Intake question.....
- SAE Factor from Old to New J1349
- 350z Short Shifter
- Resonance Question
- So what's w/ MotorDyne?
- Rev match "computer"?
- I'm I missing a bolt??
- NGK plugs that are one step colder than OEM
- Oil Change
- After MREV2/spacers...
- 03-04 MREV2 & Spacer + Mods results
- Dry vs Wet nitrouse
- Octane Power Differences
- Bottom Line - HP from mods average about $100 each
- ztube + pop charger Wanted
- Which iridium plugs are better - NGK or HKS
- Had My Car Dyno'ed and Thought I Would Share
- 03 5AT sedan... 5/16 iso and MREV2 = ...
- HorsePower!!!!!!
- K&N Filter Worth it
- Car Re-Dyno'd...
- My Dyno numbers.....very interesting
- Seattle's 1st annual Dyno challenge...
- teaching someone to drive stick....
- Where did you get your grounding gear?
- What exhaust should I get??
- Vortech + MREV2 + 5/16 iso spacers?
- Na
- Hmm... maybe I won't boost..
- Lightweight Flywheel and Clutch Installed But...
- MREV2 vs. Spacer 5AT Questions
- Horsepower & Torque - How does each relate to acceleration potential?
- Nitrouse Oxide
- UR Pulley Update: Check In Please
- Seattle-area ECU reflashing?
- Upgrade for less than $200?
- help chosing the right mrev
- Engine experts?
- Top Secret Replica (automotivemods)
- SES, Car shutting off...
- Ichiba or Megan
- jet performance chip
- Double-punch technique?
- 3 dynos, like some feedback or ideas.
- New tech at Creative Autoworks
- Intake hlep..
- sedan sound to coupe
- Dyno comparison: high-flow cats vs. test pipes
- 04 OEM G35 coupe's exhuast weight
- cobalt ss supercharged
- better intake
- The DYNO thread
- Oil and Oil filter help
- Aftermarket Radiator Hoses......
- EGT sensor?
- Recommended Service
- Oil temp and better cooling
- Quick Question
- HKS DLI II Ignition Amplifier Installed
- Underdrive Pulley sets off ebay?
- Engine sounds like a buzzsaw?!
- who has a modified engine cover?
- Check engine Light
- Where can I find an oil filter spacer (for a cooler) that will fit the sedan?
- Optima Dry Cell batteries?
- Gas gauge is actin wierd!!!!
- Does anyone have specific knowledge about the Mobil 1 oil filter?
- What kind of plenum setup...please help!?
- How to tell if what I have is MREV2 or MREV+
- High Flow Cat Question
- Nitrous
- OIL change question
- Performance Radiators
- V-8 G35
- Help!Checked My Oil.
- oil filter question.
- Installed my Injen CAI and I'm Having Issues....NEED HELP
- 60k service
- Fast ? about the stupid dipstick!
- I Am Pissed Off Please Help
